locked my keys in 1999 isuzu trooper
Postby anthonytrooper2012 » Fri Jul 27, 2012 8:45 pm
any help is appreciated.
anthonytrooper2012
Have thanks: 6 times
Re: locked my keys in 1999 isuzu trooper
Postby ravi261 » Fri Jul 27, 2012 8:46 pm
They sell slim-jims at pretty much any auto store for like $6. I used one on my door once, set off the alarm but still got the door open.
I've also used a hanger bent up on the end to hit the unlock switch for the power locks.
1999 3.2 V6 4wd Rodeo LS 178k 4L30-E
For the 1st time since 2006, everything works! (including ABS :) )
ravi261
Has thanked: 2 times
Have thanks: 67 times
Postby anthonytrooper2012 » Fri Jul 27, 2012 9:17 pm
got tx man.... geesh ill remember to def put my mag key under truck that sucked
anthonytrooper2012
Postby ravi261 » Fri Jul 27, 2012 9:51 pm
Yeah I hid one very well under my truck. Unless you knew where to look, you'll be down there long enough for someone to notice.
Use one of these:
http://www.amazon.com/GE-AccessPoint-001859-Stor-A-Key-Locking/dp/B000GTOUG0/ref=sr_1_1?ie=UTF8&qid=1343440237&sr=8-1&keywords=Magnetic+Locking+Stor-A-Key%C2%AE
Yeah it's plastic, but so are all the other options. At least this one has a lock.
ravi261
Postby Selahdoor » Fri Jul 27, 2012 10:02 pm
Ok, there's going to be someone else here who locked thier keys in the vehicle today...
These things always happen in threes, right ? LOL
Atalmost exactly the same time that you made your first post in this thread..... I had just locked my keys in my 88 troop.
I scrounged a coat hanger and got the vent window open. Then had to reach in from there and unlock the door.
Tore up the rubber weatherstrip at the front of the wing window.
-Jeff
1988 Trooper LS. 4ZE1. mua5.
Selahdoor
Forum Admin
Has thanked: 96 times
Have thanks: 165 times
Postby anthonytrooper2012 » Sat Jul 28, 2012 1:29 am
yeap ripped mine up too :/
anthonytrooper2012
Postby Metal88 » Sat Jul 28, 2012 10:31 am
I locked my keys in my 95 a few months ago, Turns out here in california is iligal to have slim jims unless you have a license to tow vehicles. so my friend got 2 flat heads, 2 towels and one of those long flexible sticks with fingers at the end and got my car open
Sal
-If you don't put any effort in anything you do in life, you mine as well be a vegetable- Burt Munro
Metal88
Have thanks: 13 times
Postby Mediamonkey11 » Sat Jul 28, 2012 1:11 pm
Done this tooo many times, now I carry one key in my wallet at all times as well as have a velcro pouch hide a key stashed on my rig.
-Tony-
viewtopic.php?t=46954
1996 Trooper LS 4X4 3.2L SOHC - Airtec Snorkel - 6000K BiXenon HIDs - 16x7.5" Snowflakes - ARB Front Winch Bumper - Vortex 12000lb Winch - Superwinch Manual Hubs - 3" lift OME 919's + Coil Spacer -OME Nitrochargers - HD Lower Links - Low Profile Droop Snubbers - Poly SwayBar Bushings - Ball Joint Flip + 1/4" Spacers, Pioneer Head Unit, Polk 6X9's in the rear doors, Polk 6.5" Front Components, Coustic 4ch 1200W Amp, Diamond Audio D912D4 12" Sub, Sub Zero 12" Vented Box.
Mediamonkey11
Has thanked: 7 times
Have thanks: 20 times
Users browsing this forum: Google [Bot] and 4 guests
